Results 1 to 2 of 2
Thread: acro 7
    dcon61 is offline Junior Member
    17
    Default acro 7
    outputting files from acro 7 some pictures are coming out with a ghosted box randomly placed in the picture. You can not see the ghosting in the pdf, only after you output it. If it is a 50% dot in the unaffected area, in the ghosting right alongside it would be about the low 40%s. Same pdf out of acro 8 runs fine. I think it has something to do with rgb icc? Any ideas?
    acro 7>os 10.4
    acro 8>os 10.5
    1,603
    In output preview you can see what is CMYK and what is RGB. Colour management settings the same in both versions?
    Use a workflow with PDFx1a!
