    J's Avatar
    J
    J is offline Senior Member
    May 2008
    177
    Default Dumb Illustrator question
    I'm sure there's a simple answer to this - but I don't use Illustrator CS3 very often so I can't find it.
    I want to have a 100% Cyan square partially over print a 100% magenta square.
    How do I make it do that? "Overprint" seems only to apply to black and not other colors.
    Also, can I preview the result in Illustrator?
    thx, J
    dabob is offline Senior Member
    Jan 2010
    Around San Francisco
    169
    Default illustrator overprint
    no question is dumb . . . in ill cs3 you use the attributes pallet and set the fill to overprint . . . done
    to preview it select view . . . overprint preview
    ALM135 is offline Junior Member
    Feb 2010
    2
    Default No Worries
    There are no dumb questions...only very poor timing.
    J's Avatar
    J
    May 2008
    177
    Quote Originally Posted by dabob View Post
    Thank you dabob. I made the mistake of searching for "overprint" in the Illustrator help file which, naturally, does not mention the "Attributes" palette.
    Sheeesh.
    Thanks again, J
