Results 1 to 9 of 9
    Soilworker is offline Member
    33
    Question Removing Alpha Channels
    Does anyone know of a way to automate the removal of non-specifically named channels in PS? I'm trying to write an action that will flatten an image and remove any extra channels (not cmyk). I was hoping that using the quick keys for channels beyond 4 would work but when I use them the action only records the name of the channel instead.
    Any ideas? I'm trying to avoid writing a script for this if possible.
    Thanks,
    Soilworker
    493
    Attached are three JavaScript files that are very handy for various clean-up activites.
    deleteChannels.js
    StripExif.js
    deletePaths.js
    Regards,
    33
    Thanks, Stephen. I'll be sure to check out the scripts.
    ~Soilworker
    Colorblind's Avatar
    Colorblind is offline Senior Member
    Montreal, Qc, Canada
    324
    Why do you want to avoid using scripts? It's a very powerful way to customize your automation needs. Anyway, on a mac you can try this AppleScript (paste the following code in Script Editor, compile then run):
    tell application "Adobe Photoshop CS4"
    activate
    --next line is to flatten the image
    flatten current document
    --next 2 lines to look for and delete alpha channels
    set kindchan to get kind of every channel of current document
    if kindchan contains {masked area channel} then delete (every channel of current document whose kind is masked area channel)
    end tell
    33
    If it requires a script then so be it. I don't particularly have a problem with it - other than I'm awful at scripting. I was only wondering if it was possible without scripting.... which it doesn't appear to be. Looks like I really need to start learning how to write a decent script.
    I'll give the AppleScript a whirl as well. Thanks, Colorblind.
    33
    One final question. Can you recommend a good resource to learn this sort of scripting? I think my preference leans towards JavaScript but AppleScript would be good to learn as well. Would you recommend books, online tutorials etc?
    I've gone so long without really needing to know scripting but with the direction my job has taken it would behoove me to learn.
    493
    Soilworker, over and above the Adobe resources that ship with their products, the following seem to be the most common places to discuss Photoshop scripting:
    Adobe Forums: Forum: Photoshop Scripting
    Photoshop Scripting Community Forum :: Index
    If you are wishing to script InDesign (why no actions!), then you would need to look at different forums.
    If you are Mac based, then AppleScript would probably be the easiest to learn, however if you have a web or other coding background and you also use MS Win, then JavaScript is cross platform and a good second choice...with VBscript also being a MS Win only option. It's all Greek to me!
    The 3 scripts posted above were originally obtained from the Adobe Exchange site.
    Best,
    Shawn is offline Senior Member
    Topsham, Maine
    189
    Quote Originally Posted by Soilworker View Post
    For online help with AppleScript I'd check out the resources at macscripter.net. Specifically the section for absolute starters.
    MacScripter / AppleScript for Absolute Starters
    A great printed book is AppleScript 1-2-3 by Sal Soghoian and Bill Cheeseman
    Peachpit: Apple Training Series: AppleScript 1-2-3
    The big reason to use Javascript for this is that your scripts would be cross platform. On the other hand, AppleScript is probably a little easier to learn.
    Shawn
    Colorblind's Avatar
    324
    I know nothing about Javascript but do agree about the AppleScript links and books suggested by Shawn and Stephen. I would probably start with this PDF: http://files.macscripter.net/sourcebook/AS4ASb2.pdf just to understand the basics of the language. AppleScript is a very important part of my actual workflow. Sometimes I get a bunch of 25-50 InDesign files I have to preflight, make PDFs of and send by ftp or email to various publications. With AppleScript the whole process is a matter of minutes not hours.
