Results 1 to 7 of 7
    pajdzn is offline Member
    50
    Default Acrobat 8 vs. Acrobat 9 file opening
    Has anyone experienced Acrobat 9 being incredibly slow to open files? I opened the same pdf in Acrobat 8 and 9 and in Vs. 8 it opened in 3.3 seconds while in Vs. 9 it took over 3 minutes and wasn't completely previewing when it was done.
    Any theories would really be appreciated. Meanwhile I guess it is back to Acrobat 8 again.
    Thank you
    1,528
    Was that incuding opening the software? Could be you have different preview options, there is not nearly enough information to find the answer to your question. Would need information about the file, possibly even have a sample file. Would need information about your computer and about Operating system, and possibly more.
    zoran's Avatar
    zoran is offline Senior Member
    Ottawa, Canada
    268
    If you have Pitstop 9 installed on your Mac, opening PDF from SMB network share, that is your culprit.
    Just one of the possibilities.
    445
    Quote Originally Posted by pajdzn View Post
    Turn off any 3rd party plugins that you have installed and try again. Many plugins haven't been updated for full Acrobat 9 support including its "delay loading" feature.
    50
    Thank you all for your responses. Zoran has hit the bullseye, that describes our setup to a T. Are there any solutions to the problem, perhaps just working off the computer and not the network?
    Joe
    Joe is offline Senior Member
    567
    I open PDF's into Acrobat 9 all day every day from an SMB share and have no issues with it.
    Joe
    zoran's Avatar
    Ottawa, Canada
    268
    I submitted support request to Enfocus than it took long time to get any response.
    Finally when I got response, they told me it is "known bug", probably known internally in Enfocus since their knowledgebase does not mention it.
    Finally I was told it will be fixed in next update.
    Next update 9.02 came and it wasn't fixed.
    When I asked what happened to fix they said it was too close to release of 9.02 update so it will be in next, next update.
    I've been waiting since than, probably couple of months now without hope.
    In meantime I've had to uninstall Pistop 9 from all Mac production machines and revert them back to Pitstop 8 under Acrobat 9 which works ok. Pitstop 9 brought our Production to it's knees.
    Be careful when you uninstall Pistop 9 not to leave any leftovers.
    Here is good article on how to remove Pitstop 9 on Mac from Enfocus Knowledgebase:
    http://www.enfocus.com/kb.php?id=6031
    Good luck and keep an eye on next update of Pitstop, 9.03 if it ever comes out.
    Last edited by zoran; 02-26-2010 at 07:20 PM. Reason: Added link to Enfocus article
