    rande is offline Senior Member
    192
    Default CS4 Photoshop cropping?
    I've never had a problem with this, but all of a sudden when I go to crop it gives me
    a gray window and the image is gone?
    I take it into CS3 and it works fine.
    Any ideas?
    thanks
    motormount's Avatar
    motormount is offline Member
    Nov 2008
    75
    I hope you don't mean the ''shield'' checkbox underneath the menu bar!
    If this be the case ''uncheck'' the shield box-how can we write this in proper english?- and the image will return!
    Verdant is offline Member
    Jan 2010
    45
    It could also be that you accidentally typed in a dimension in the crop tool bar and it's making the crop size small enough that it's cropping the entire image. The shield checkbox will make everything grey if this was the case.
    500
    Verdant has it right. See attached.
    motormount's Avatar
    Nov 2008
    75
    This could be it,but you need to crop it first-i think that rande ''looses'' the image before he completes the crop action,at least that's what i understood!
    tschroe is offline Junior Member
    Feb 2010
    6
    Yep - check the width/height and make sure it's not pixels (i.e. 4x5 pixels - that would be very, very small).
