Results 1 to 8 of 8
    padrao's Avatar
    padrao is offline Member
    Nov 2007
    Portugal
    48
    Thumbs down Long rip time, complex PDF.
    Hi i need one solution for the PDF`s with very complex vector´s inside .
    The PDF is small format, but this will mounted on one sheet size 1000x700, and after send this job to metadimension it take 2 to 3 hours to output the job on CTP .
    My question is what can be done on PDF or application to make it more easy , without convert the vector in image .
    All the experts are wellcome . . .
    Here is the link for the file .
    4shared.com - online file sharing and storage - download PDF file.zip
    All the Best
    Padrao
    CHM
    CHM is offline Senior Member
    May 2008
    171
    This is a question that the people of metadimension should be able to help you with.
    David_Modprint's Avatar
    David_Modprint is offline Junior Member
    Nov 2009
    Stillwater, Minnesota
    11
    Just for fun I downloaded the file and ripped it in Navigator 8.1. It only took a minute or less to process but I was ripping it at a very low line screen. I have found that this upgrade really improves rip performance for complex PDFs and files that contain transparencies. What rip were you using and what is your final line screen...just out of curiosity. Not sure if that helped with your concern or not...
    akalaray's Avatar
    akalaray is offline Member
    66
    Default Down loaded and Ripped
    I Ripped and Trapped your file on our Meta Rip 7.5.1 - Time 1 minute 10 seconds
    padrao's Avatar
    Nov 2007
    Portugal
    48
    Default Rip time
    The Rip is Metadimension 7.5 connected to PrePress Manager 4.5 .
    To rip one file, there is no problem, but when outputed from one Layout,from signastation on size for sm102, the case is diferent . Try to mount for paper size, 1000mmx700mm .
    All the Best
    Padrao
    Quetu's Avatar
    Quetu is offline Member
    Feb 2008
    36
    Default One solution
    In my old rip harlequin (6.4) to make mounting 700x1000 = crash.
    But if I rip the label and get this:
    www.qpdf.es/downloads/Recombiner.pdf
    and make the imposition I get this:
    www.qpdf.es/downloads/imposition.pdf
    and send it back to rip:
    Ripping time: 9 minutes 56 seconds
    Saludos!
    toronar is offline Senior Member
    Nov 2007
    130
    Quote Originally Posted by padrao View Post
    All the Best
    Padrao
    MetaDimension 7.5.1 and PPM 4.5.2 here, RIP time 21 minutes, 36 seconds.
    Spool time: over 40 minutes. Combined gives around 1 hour for a 1000x700 form filled with these.
    Regards,
    toronar
    Modern PrePress is CSI: PDF.
    Nov 2007
    130
    Same software as before, but this time I ripped the form with CPSI instead of the APPE.
    As usual, CPSI blows APPE out of the water in speed: 3 minutes 19 seconds rip time, 3 minutes spool time for a grand total of around 6 and a half minutes for the 1000x700 form filled with the PDF.
    I would say Adobe has a lot to optimize in its APPE
