Does anyone know how to extend only the outer pixels of an image?
My task is to prepare an image for die-cutting (a bottle shape), I can't scale the die-cut path because important parts of the image would be missing then.
I've seen pixel-based images where someone had extended just the outer pixels to accomplish this.
On straight edges you could use a one pixel wide selection and scale it until it fits your needs....but on irregular shapes?
Follow these steps:-
1. Make selection of image area you want to bleed
2. Make separate layer of selection ( you can merge back later)
3. Menu > Select > Modify > Feather (3 pixels ok but depends on bleeding required)
4. Select > Inverse
5. Menu > Filter > Other > Minimum
6. Adjust pixels using preview to taste.
3. Menu > Select > Modify > Contract (3 pixels or so is ok)
4. > Select > Inverse
5. > Select > Modify > Feather (1-3 pixels ok but depends on bleeding required)
NB: There is no rule for this you just have to keep testing with different settings until you find the best result. I use this bleeding for jobs that require trapping e.g for rotogravure output. ronmulli@yahoo.co.uk
