checklist for a perfect PDF for printing
can anyone provide me with a checklist for a perfect PDF for printing( black type,rgb 2 cmyk,transparecies ect....)
It really depends on the PDF receiver... If you want to have a quick idea, go to the preflight pane in Acrobat 9 Pro, select one of the preflight profiles under "Prepress" (choose the appropriate situation), click on "Options" at the top right of the Preflight pane and select "Create Profile Summary...". It will make a PDF of everything that preflight profile checks, it should give you an idea.
FlightCheck for PDF
Similar advice with a twist; download a 30-day, full-working demo of FlightCheck v6.75, which is a stand-alone preflight app for PDF files, but also Adobe Illustrator, InDesign, Photoshop, QuarkXPress, etc layouts here:
Preflight Tool for Adobe InDesign, QuarkXPress and more - FlightCheck
Drop a PDF on the icon (So that the settings will "auto" switch to the PDF checks) Then, open the "Ground Controls" and you will see a host of preflight profiles for PDF-Print-Jobs. Choose the PDF/X-1a and that is more or less what you want, depending on specifics of your extended print workflow.
Just remember, a perfect PDF stems from the source DTP layout, where FlightCheck can also assist:
Preflight Checklist Lists for Preparing DTP Files for Print
Have a great day,
David
Markzware
"The makers of FlightCheck"
Consider PDF/X-4!
 Originally Posted by davidmwe
... Choose the PDF/X-1a and that is more or less what you want, depending on specifics of your extended print workflow.
From our experience with both designers and print service providers, you really should take a look at PDF/X-4 as opposed to PDF/X-1a. PDF/X-4 provide support for live transparency and color management. PDF/X-1a assumes that you know exactly what the device characteristics are of the device and/or press that your content will be output with. You are much more likely to avoid transparency rendering artifacts and color problems with PDF/X-4 than with PDF/X-1a. As always, though, check with your print service provider before choosing to use one standard or another. (A good number of print service providers are still trying to get past the 1990s!)
Dov nailed it.
PDF/X4 and the native files is what I ask for every time. If there is anything that needs correction I can adjust the native files and make a new PDF/X4. PDF/X4 is pretty much a golden standard to anyone using the Adobe PDF Print Engine (APPE) workflow.
PDF/X1a is my preference when working outside of an APPE workflow. There are still a number of proofing RIPs that do not utilize the APPE and issues will certainly come up if you have live transparency in the PDF.
I now work with folding cartons but when I worked in commercial litho getting PDFs in spreads or pre-imposed was always a nightmare. Please provide to size in single pages with bleed and slug settings utilized. Most designers have no idea how nightmarish imposition can be when given no bleed setting, no slug setting and in spreads.
Good message Dov and Chevalier. I think it is wise as well what you ask for Chevalier;
"PDF/X4 and the native files is what I ask for every time."
Ugh - So Unnecessary!
From Quark or indesign or Illustrator - and GENERAL web/offset conditions SWOP CMYK etc-
Select "Press Quality"
Select 0.125" Bleeds - IF your document has bleeds.
Select "Spreads" IF your document spans multiple pages-
Use Rich Blacks in areas of heavy solid black.
Press Quality PDF to size, with bleeds pulled, set to the CORRECT page size, so the trim marks actually define the trim. NOT just throwing art on any size board and throwing crop marks ON it - Looking at YOU Illustrator PPL! I mean the actual crop marks DEFINE the actual trim correctly - If the Geometry is CORRECT, it goes thru prepress a lot faster and easier. That is ALL you EVER need - UNLESS you're imaging to some HUGE line screen frequency - like over 300 LPI or other UNCOMMON things.
ALSO IF using QXP thru Ver 8 - AND you are using PMS or require Spot colors, you need to take it off of composite CMYK, and put it to Composite CMYK + Spot.
THAT IS ALL PRESS QUALITY, with CROPS,BLEED to 1/8 inch, With correct Geometry
very very simple
@david The press quality settings has many weaknesses eg gives you no clue as to the colour settings of the PDF creator. I would not want spreads!
But one thing you all are forgetting is to mention that if you have color settings configured badly you will get inconsistent results. If your colour settings are not under control you will never get good RGB -> CMYK, because that is where you define how to tag untagged colours, if certain profiles are ignored, what method of conversion etc.
Creating a PDF is like serving a meal. You can make it look like it was made ok, but Photoshop and Illustrator is where you have your pots n pans. A perfect PDF needs perfect art.
Preflighting color
Yes, very good points. Color is an area we often dive into on the preflight side, especially recommended to check at the native stage in or on the source files before the press-PDF is generated:
FlightCheck- preflighting color; a prepress operators overview
I love the cooking analogies (for more reasons than one!). "Proof is in the pudding" we say (It may look great, but does it taste delicious.)
Since I have upgraded to Google Chrome I can not get access to the browser settings such as File, View, Options, Bookmarks, etc. that I am used to seeing at the top of my home page. I now only see an abbreviated menu at the top of each page - go forward, back, reload, a home icon, bookmark Create Star, my URL, Full page icon, and wrench.
This is probably a dumb question, but how do the page back up to display the name of the settings, like file, view, etc.?
